kenneu
May 07, 2016Explorer
Thank you to those of you that provided some leads on good used units. I've found a couple of used units and I'm seriously considering one or the other. The first is a 2014 30QBSS Salem which has bunks in the rear, a super slide, and is pretty much like new. They say they camped twice. It looks more like never. The second is a 267BHS Jayco Jay Flight Swift. Both have a 30" entry door and a super slide and the layout is pretty much identical. The salem appears a bit heaver duty and it should as it weighs almost 2000lbs more. I wouldn't be able to regularly tow it with my F150 5.4L Tow Package vehcile even with a disty hitch. I could probably get it to the ranch where it will stay, but I'd probably just rent a tow vehicle for the day. The Jayco is a 2013 unit and while excellent condition shows some use. The Jayco also has a 30" door and a super slide. Both are similarly equipped. The Jayco weighs a whole lot less, though, and I could tow it to an alternate location if so desired... Any experience with these two units? The owner of the Jayco wants 14,500 and includes a distribution hitch and the owner of the salem wants 16K. It has a couple of upgrades like a 15K AC but nothing much beyond that as it came stock with a pretty good package.
44,066 PostsLatest Activity: Apr 10, 2026
