darleyhavidson
Apr 03, 2018Explorer
wills670 wrote:BarneyS wrote:
I have been using a whole house filter, purchased at Home Depot, for the past 14 years. I use a charcoal filter in it which filters finer and also takes out any funny taste in the water. Change the filter as needed. I put the whole thing in a plastic milk case and then on the ground under the edge of our slideout. I use brass quick connect fittings on all hoses. That keeps it out of the sun and also keeps it cooler. This has worked well for us for many years, lasts longer, and is not expensive like the smaller inline filters are.
Barney
I use the same thing a whole house filter with the charcoal filter but I purchased fittings for an inline hookup to my hoses and use a short hose to run from the faucet and just place the filter on the ground. Then as an extra precaution to getting bugs and stuff I drain the water out and hook the short hose back up to the other fitting.
Did you notice any water flow restriction with this setup?
44,066 PostsLatest Activity: May 13, 2026
