darleyhavidson
Apr 03, 2018Explorer
BarneyS wrote:
We have had no problems at all with the brass fittings leaking and have noticed no water flow restriction. We use a high quality pressure regulator at the hydrant end that keeps the pressure around 50psi all the time and always allows excellent water flow.
When the flow slows down (rarely happens) then we know the filter is plugged up and time to replace the element.
Depending on location, we can go a whole winter or summer on one filter element.
In addition to the whole house filter outside, we have an under counter water filter with a separate small faucet on the kitchen sink for drinking water. It uses a special, quite expensive ($20-30) filter that we replace every year.:)
Barney
Ok, good to know. I will do some research to see what is available locally. The RVWaterfilterstore.com seemingly has what I need though.
44,066 PostsLatest Activity: May 13, 2026
