- Edd505ExplorerThe first thing you learn with either is not to use it in freezing temps unless you don't want to go any where till they thaw out.
- burningmanExplorer IIWhen I was a teenager we used to call it a "U brake"! Get rolling about 30-ish, hit the "U brake" and crank the steering wheel - instant U turn!
Johno02 wrote:
The Mechanical brake that is installed on our Motor Home doesn't really seem to be anything but that. I really don't think it would stop the rig, and I certainly would'n depend on it to park on an extreme slope. It is connected behind the transmission on the drive shaft, and not to any of the actual wheel brakes.
That parking brake should hold the RV parked in almost all conditions. I recommend shifting to neutral, set the parking brake and see that it holds before you place it in park. If it does not hold then have it serviced. Same goes for all vehicles.- RubiranchExplorerMine has both
a park brake on the left side and an emergency brake next to the accelerator pedal - Tom_AndersonExplorer
Reddog1 wrote:
If it is not an emergancy brake, why are brake line locks illegal in california?
I don't think it's so much that they're illegal as that they don't qualify as a parking brake. To be legal, a parking brake needs to be independent of the service brake system, which a line lock is not. If you were to blow a hydraulic line, for example, a line lock wouldn't help.
There are some disk brake systems that use the same calipers with a mechanical actuator, and there are air-braked vehicles with spring brakes that share the same foundation brakes, and they're obviously legal. So I don't know exactly what the law says, but that's the basics of it.
If you want to look it up, it should all be in the Federal Motor Vehicle Safety Standards. - mkirschNomad II
free radical wrote:
Illegal?
I guess no Camaros for you then :)
https://youtu.be/xFWfpKrQRpQ
Just because speeding is illegal doesn't mean that nobody speeds. Maybe not in California because you have a hard enough time getting up to the speed limit, let alone exceeding it, but if you've ever been outside California, you'd know what I mean... - theoldwizard1Explorer IIThe term "emergency brake" and "parking brake" are used interchangeably in the US. In the Midwest, most are frozen in the off position within 2-3 years because the are never used.
- d3500ramExplorer III
trail-explorer wrote:
Your title and first post have 3 things listed:
Parking brake, emergency break and emergency brake
Parking brake = what modern cars today have as standard equipment.
Emergency break = needing to use the restroom very soon.
Emergency brake = an ancient device used on early automobiles.
Flintstone brake = a device used on cartoon vehicles without shoes (not to be confused with break shoes...LOL - trail-explorerExplorerYour title and first post have 3 things listed:
Parking brake, emergency break and emergency brake - BubtoofatExplorerMy truck (2500HD) has disc brakes AND drum brakes on the rear, with actual brake shoes. I would say that the drum brakes were actual emergency brakes, meaning you could apply the e-brake at speed and safely come to a stop.
My brother's truck (1500) has very thin stamped steel "shoes" with some type of friction material that is about 1/16 of an inch thick. I'd call that a parking brake. If you were to apply his parking brake at speed I'm sure the thin material on the shoes would vaporize in the blink of an eye and disaster would quickly follow.
Mike
44,052 PostsLatest Activity: Nov 23, 2025
