jfkmk
Oct 06, 2017Explorer II
Why a pickup?
We have a 17' TT that we tow with a mid sized body on frame SUV and it tows great. It's not going to win any drag races towing the trailer, but I've never been in a situation where it significantly s...
Powerdude wrote:
Well, I can tell you for sure that with less electronics and less power, and less gizmos, vehicles were easier to diagnose and repair than newer vehicles.
One NOx sensor can knock out an entire emissions system, and put a vehicle in limp mode now. You need a tow just to get home.
Alternators used to be simple to replace and were usually $69 bucks, and one belt to change. Fuel filters and/or most fuel pumps used to be in line on the fuel line. 10 minute job to change if you had a clog or bad gas. Now you have to drop the whole tank to change a fuel pump.
You could pull the distributor off, clean the points with a little sandpaper, and be on your way. Not anymore if an ECM module goes out, its $799 just for the part.
I'm not that old either, but I do remember buying a distributor cap for $5.99 and swapping it out in the parking lot. 10 minute job and I was on my way.
