- totaldlaExplorerThere's no technical reason why manufacturers can't - its just cheaper to do it the same old way.
It would be much more stable, and much easier on the tow vehicle to have a 4 wheel wagon suspension. Add rear steering and you'd eliminate outcast.
The technology is available, (rear steering common in Italian busses), but it costs more. - HannibalExplorerLike our 28RLS Jayco, 2/3 of your trailer is in front of your trailer's axles. This makes for a very stable rig. Too many travel trailers have axles too far forward in an attempt to keep tongue weight down so unsuspecting buyers believe their lightweight tow vehicle can safely tow it within the TV's weight ratings. Then the quest for sway control begins. Your rig has one pivot point. A wagon type rig would alleviate the tongue weight issue but it would add another pivot point making backing the rig a challenge.
- HannibalExplorerTowing a car on a dolly or on all four behind a motorhome is doing exactly what you describe. Here's about as close to the little red wagon concept as you'll likely get with an RV. Backing these things into a spot on the right would be cause for divorce.
http://fifthwheelst.com/automated-safety-hitch-system.html - 3oaksExplorer
And backing up, forget about it
? Apparently there're aren't any farmers replying to this thread.
How do you think we got the hay wagons into the barn all these years? :R
Definitely good for highway use though. ;) - nickthehunterNomad III
skipro3 wrote:
You can back up a trailer like that. It's called a "dolly lock". It's done every day of the week on double bottom gravel trains.
Because you can not back up a trailer like that...
You may also be amazed to know they also go around corners just fine.
A dolly lock would let you to back up and RV the same way. I'm not saying it's practical, just possible. - TerryallanExplorer II
DanNJanice wrote:
Good question.
I am less sure about the stability argument, as I see double and triple semi trailers all the time, they seem to work fine.
I'm thinkin they have lack of stability as well. That is why they are called WIGGLE WAGONS - rbpruExplorer IIThe reason the axle are where the are is because it is the best placement for a travel trailer; at the lowest cost.
Semi-trailers and boat trailers work best near the rear because that is what is best for them.
Four wheels wagons have been used on the farm for years but they are more expensive and do not seem to offer any significant advantage in the TT industry. - myredracerExplorer IIProblem is a large difference in turning radius and tracking for the front (steerable) axle and the rear axle. Best example is semi-trucks and trailers as the two diagrams below show. In a tight right-hand turn a semi-truck and trailer typically swing as far left as they can just before a turn and take up 2 lanes getting thru the corner. It would be very difficult for a TT owner - expect a lot of accidents. Commercial truck drivers are trained and RV owners aren't.
- hedgeExplorerthe larger gravel truck pups are built just like this and the drivers manage to back them up. Quite often they back them up so that the trailer is beside the truck so they can then dump the truck, it's pretty cool to see.
ps, back in my younger days I worked as a gravel checker. - prichardsonExplorerAs others have said - handling. A wagon configuration does not track well going forward (the higher the speed the worse it is) and it is nearly impossible to back.
44,056 PostsLatest Activity: Jan 19, 2026
