noteven
Oct 08, 2013Explorer III
Desertboy wrote:06Fargo wrote:Yes Sir I do! I think about it constantly, There is a camper made that will hold up, and its cheaper than what you quoted, and half the weight. I don't currently own one But when I buy new It will definitely be solid aluminum frame/ skin, cabinets and all.
Does anyone else drive around thinking about designing a really well made RV ?
I didn't quote any $ Desertboy. Our Snowbird "Off Road" is part way there - it is made with real plywood and oak with decent appliances - but what stands out is the workmanship where wiring and plumbing is run and supported neatly where you can't see it, and how the upholstery is finished and the caulking... like someone cared for what they built. In the paperwork was an "enjoy your new Snowbird" paper with the signature of all the factory people that worked on it.
Snowbird/Snowriver - Mr. Bob Meher passes away in 2013.
But back to your design - will it have proper high fuel efficiency radiant heating and a heat recovery ventilator to control humidity? And tracking solar panels? And a properly insulated floor? And stairs you don't fall off? And a water treatment system?
