3 tons wrote:
KKELLER14K wrote:
Why is diesel more expensive than gas can anyone explain it? I'm talking fuel....but yes engines is the same question.
Diesel fuel use to be cheaper, but what changed the equation is the EPA’s low sulfer requirement...To reduce sulfer to ultra low levels in diesel requires private investment and the construction of new multi-million dollar hydrotreating units where sulfur is bonded onto Hydrogen thereby converted into H2S gas for removal...The capital to build these costly units must be recouped at the commercial pump...
http://technomanage.com/Process%20Technology%20Database/Refinery/Hydrotreating/hydrotreating.htm
Where I fill up my Ford -diesel often is the cheapest fuel.
Problem is that truck stops converted to B20, what is fine for Ford, but my sedans should not go above B5.
How crazy it is shows the today's shot from California.
The Valero station sells B5 for $4.09, but the same people operate Chase truck stop on left side, who sells B20 for $3.34
Cheapest regural at nearby ARCO is $3.59 or $3.83 at Valero
Click For Full-Size Image.
