mileshuff's avatar
mileshuff
Why do I keep blowing out tires on my truck?
The last three sets of tires on my 2007 Ram 2500 have had one tire blow out. Always the same, passenger side rear. Have not weighed my trailer but specs are 7,000 dry, GVWR 10,500, pin weight 1,500. Probably closer to 1,800 to 2,000 lb pin weight. I tow with all tanks empty. I keep rear tires at 80 PSI checked before every trip.
First two sets were Michelin LTX MS and MS2. Third set was Yokahama YK-HTX. All blow outs occurred around 3-4 years with 25-30,000 miles on them. Tons of tread left. Have new set #4 on now, Michelin Defender LTS MS.
Why can't I get more than 3 years and 25,000 miles on my truck tires?
  • Anonymous's avatar
    Anonymous
    Not applicable
    Is there somewhere you go on a regular basis that could cause damage to that RR tire, a curb, rock, etc ?
  • What caused the blowouts? Tread separation, sidewall blowout, or other stuff? May be time for a cheap TPMS to see what that tire is doing.
  • Check the weight rating (in pounds) embossed on the tire side wall. Now go check your total loaded vehicle weight and then weight on the front axle and weight on the rear axle?
