Community Alumni
Aug 20, 2015busterbrown73 wrote:
This is what I'm unsure of... "Who makes the better ultra light quad bunkhouse". I've read many reviews on different units and there are such disparities between owners. Cruiser RV's Shadow cruiser bunkhouse had many complaints about under rated axles and water leaks in years 2012-14. Since their parent company was recently bought out by Thor, I'm wondering if quality has gone up since then? The dealer is telling what I want to hear...I know he is.
You have to take some online complaints with a grain of salt. "Underrated axles" is a common complaint. People look at the combination of axle weights, discover that it doesn't meet the GVWR of the trailer, and automatically assume that the axles are underrated. What they forget is that the trailer's tongue typically carries 10-15% of the trailer's weight. Some manufacturers use this method to get away with using lighter axles. If the axles are actually underrated then you would see some dramatic failures like bent axles. The manufacturer would also probably be in hot water with the government for not meeting minimum standards.
Leaks happen and are easy fixes. Even trailers that are commonly considered high quality, like Airsteam, has a few that roll off the line with leaks. Whichever trailer you go with, have the dealer test it for leaks before you buy. Sometimes the leaks are from the factory, but some of the complaints you read are from neglect. A lot of people don't bother to inspect their trailers and are quick to blame the manufacturer for their leak. Caulking, sealant, and seals don't last forever. Maintenance is the key to having a problem free trailer. The best defense against leaks down the road would be you.
Just about every trailer out there you'll find people who rave about never having a problem and those who complain about having a lemon. Subpar quality control is a problem that affect the majority of the industry. You may get a good one, you may get a bad one. With this industry it's kind of like gambling lol.
Focus more on how the trailers are constructed and what materials they are made out of. What are the walls made of? What's the R value? What's the construction of the floor? Etc. You'll probably have to contact the manufacturer directly since this info can be hard to find in brochures. If you aren't sure if something is good or bad, just ask.
44,056 PostsLatest Activity: Jan 12, 2020
