maddog348's avatar
maddog348
Why does my Truck Camper list toward the driver side
Of All the things I've ever lost ~ I miss my Mind the MOST ~~ Need help or a swift kick in the ....
Have a 2006 Toyota Tundra double cab. SR5, 4.7 gas ~ 6'6" bed ~ spray in bedliner. ~~~~ Bought 2017 4WheelCamper "Hawk" Shell Dec. 18,2017 [Factory installed date of purchase. 965# +batteries +2 10#propane furnace/cabinet.] No 110v ~ no water ~ no potty ~ no etc,etc, Pretty much nekkid, Camper 'rests' on side to side 1x4's fore & aft of wheel wells rear most 7" in from rear end of camper. 1/4" between camper sides and tail gate opening.. 1 hand thickness camper bottom and floor of truck [I am old my hands are not very thick] Camper sides ride about 1' above sidewalls bed of truck.
Had BF Goodrich ~ All Terrain lt625/70r16 "E" Apr/2018 ~ Firestone RideRiteAirBag pkg installed Oct 2017
Only taken on a few trips as Work in Progress. built side to side bed platform below cab/camper window, Movable Storage under, Campsite leveled as needed with wood blocks ~ never a problem, Carry water bottles ~~ Use Thetford 135 Feb this year.
OK Earlier this year noticed camper 'listing' toward driver side. Unit is usually parked in backyard. OK OK Know backyard not FLAT & Level ~ BUT Driver side rear of camper 1-2 inches lower than Passenger side. Measuring from bottom of 'Jack' bracket to ground. Air bag a little low on that side. Pumped up to 30# ea waited few days down again. Took back tire shop a couple pf times ~ new lines. Still not good ~ Put new 'pod on driver side. WAITING. A little low but could be the yard. Second 'pod'put on passenger side today. Both air pods aired up to 50#. No matter where I put it ~ Which way I face it driver side 1 1/2' low
Also at the last measures RT,RR., turnbuckle a little loose. ~ NEVER ~ Loose before ~~ Connected or coincidence WHat do I measure now. Is this normal. Is this Usable?? Can it be possible that the camper was heavy enough on the driver side with Batteries;Propane ~Furnace~~to cause bed to be lower on that side.
Never noticed a side to side difference until after camper in stalled. Never had 'wings' I had to duck under before . HELP. If can't be helpful ~~ Please be Kind. Thanks ~~ K
