ktmrfs
Oct 19, 2013Explorer III
Is it easy??? kinda depends on your DIY skills. Moderate DIY skills and tools and it's pretty straigthforward. Was very Easy for me. yes, there are multiple posts on how to do it. DW says it's by far the best mod so far.
FWIW, start with a replacement electric spark ignitor for bbq grills with 4 (yes four) output terminals. That way you will end up with electric ignition for the burners and over. and it will come with one wire that has high temp insulation for the oven.
And don't think you can do it with a ignitor with 2 or 3 outputs and put several in parallel. Won't work. on the ones you parallel only ONE will spark, not both/all.
44,071 PostsLatest Activity: Aug 30, 2026
