Huntindog
Oct 20, 2013Explorer
ScottG wrote:ktmrfs wrote:
Is it easy???
And don't think you can do it with a ignitor with 2 or 3 outputs and put several in parallel. Won't work. on the ones you parallel only ONE will spark, not both/all.
You have to ground the unused circuits and then it will work.
There is some miscommunication here.
Using a igniter with two or three outputs will work for the oven and one or two burners.
But to get the electronic igniter to work on all burners as well as the oven pilot light requires one with as many total outputs as you are wanting to light.
Since most stoves have three burners and one oven pilot light, then a four output igniter is needed.
44,071 PostsLatest Activity: Aug 30, 2026
