riltri
Jul 20, 2021Explorer
Weight is not an issue. But, putting it in the slide-out prevents the refrig from being vented properly....out the roof. Instead, it is vented out the side which can lead to overheating and cause the refrig to shut down/not work properly. If this does happen to you, installing fans in the exterior vent to draw the heat out works well and only cost $150 - $250.
