drcook
10 years agoExplorer
Wide Stance Equa-Flexes are here
I recently got the bug to do something about our unit's suspension. I did a trip from Ohio to Alliance Neb and back across I-80. Some sections of 80 have some bad concrete and the truck and trailer "porpoise" I guess is the term. Also, the trailer has a couple 1000 miles on now, so the original cheapo spring bushings are probably gone.
I had dishes come out of the cabinets and other stuff walked across the floor of the trailer.
We have a 30ft Crossroads Cruiser with the Lippert "wide stance" axle setup. Crossroads called it "Secure Stance". The wide stance made it a bit more difficult to track down an equalizer damper.
I finally was able to work out the appropriate Equa-Flex model and tracked a set down.
The absolute best price on a pair is from Eastern Marine/Trailer Super Store. They have them on sale right now for $175.00 for the pair. (plus shipping)
I also got Lippert's Never Fail bushing kit.
I am thinking about getting these while they are on sale
http://www.easternmarine.com/lippert-bolt-on-gas-shock-kit-281281
I had thought about the Joy Rider Shock System, but it is $500 to do both axles (plus shipping) -vs- $200.00 plus shipping to use the Lippert kit.
Now I have to work out a method of safely holding the trailer up while I drop the axles (and jacking it up for that matter) and undo the springs. My existing jack stands and jack are not tall enough.
Harbor Freight has a tall bottle jack, but the base doesn't look big enough from the picture, nor the end that gets the frame. I could use my friend's lathe and mill to work something up unless someone has some good suggestions about how they have done it that they would like to share (hint hint). Tall enough jackstands are going to be difficult to find. If I can find a place that will install them for less than what I have to spend buying stuff, I would gladly pay to have someone do it for me.
