jus2shy
Dec 19, 2013Explorer
oilslick wrote:
I would like to point out a couple of things. Ford and Chev don't make a manual transmission in a 3/4 or one ton truck so that leaves only the RAM Cummins diesel. In the paper version of the owners manual it states that if you do not use full synthetic 5W40 oil below -18C engine damage will occur.
While the Cummins engine is in "regen" there is no direct indication other than the fuel burn drastically reduced, if you have an EGT gauge you will see the increased exhaust temps displayed there. During regen exhaust gas is recirculated back into the intake just before the grid heater, if the engine is not at operating temp during regen that recirculated exhaust gas also contains unburnt diesel fuel which eventually runs down the cylinder walls and dilutes the oil causing the engine to "make oil" this unburnt fuel also runs back down the boost tube and collects at the exit to the precooler. Anyone start to see any problem yet?
If it's cold out the grid heaters will be on causing the unburnt fuel to become balls of hard carbon, these balls continue to grow in size until they can't get through the grid heater and then reduce the amount of airflow allowed into the engine. If a hard enough piece manages to get through the grid and out into the exhaust in one piece it can damage the turbo. Our 2011 3500 manual trans truck which was only driven on the hiway while towing at least 8000lb cargo trailer and often much heavier goose trailers even with a fast idle, winter front, synthetic oil, had problems from new. Oil change messages at 1500km and the oil so overfull and diluted with diesel fuel you wouldn't believe unless you saw it. The truck was forever at the dealer with exhaust codes, they changed a few O2 sensors but this is no way to treat a $15,000 engine if you have to replace it.
The truck would barely run in the end and the huge truck dealer here was no help. With about 30,000km on the truck I decided to tear it apart and document with pictures what I found. After my work the truck ran great and oil changes were in the range they should be with no oil dilution. The price was loss of warranty at 30,000km. I showed the pictures to the service manager, he was not surprised at all so he must have already seen this many times before yet would do nothing to correct it. I honestly don't think it was the dealer or the service manager, I think this came from Chrysler. They know the problem exists but the fix was the addition of DEF on the 2013 truck. I love the Ram trucks especially the 2013 with the Aisin trans but people need to know exactly what they are getting into before buying a Cummins powered truck and Chrysler won't tell you neither will the sales person.
Well, since going to the new SCR setup, the new Cummins reduces EGR from the old 30 to 40% values down to roughly 10 to 15% values. A few people seem to have opened up their 2013+ RAMs and found that there's not noticeable amount of soot going back into the intake (at least at around 20 to 30k miles). The whole massive EGR approach is a mistake in my book and that's why even International who Poo Poo'd all the SCR guys had to come crawling to their arch rival (Cummins) to get an SCR system to meet current emissions standards and hopefully get out of their warranty rut that they are in. We use Cummins in our transit vehicles and have seen issues with the 2007-2009 ISL's. Lots of EGR, lots of soot, lots of issues. But with our newer fleet which has about 40,000 miles, we're not seeing anywhere near the issues that we did with our 2007 lot. SCR is a very good thing. I'd rather pay the price to change out the SCR dosing/injector (which is dirt cheap) than deal with the soot, clogged EGR valves, and other associated issues that all the manufacturers had from 2007 to 2009/2010. I advise all my friends to avoid those years for any manufacturer because of the new emissions "Growing pains".
