Cummins12V98 wrote:
Question, should I follow my 14k GVWR on my 2015 RAM DRW?
I am not one to go by factory GVWR since it is based on outdated trucks and needs to be updated for todays trucks instead of those half a century ago. Nor is it legally binding to me in any way.
I do go by GAWR since is not based on any government regulation, but rather the limitation of the actual hard parts. In this case, you can't go much over 14k since both of your GAWR add up to 15,850 lbs. The GAWR's of my 2500 add up to 12,500 lbs, but has a GVWR of 10k, while the the 3500 version of my truck have GAWR's that add up to 13,000 yet has a GVWR of 12,300. So your combined GAWR is 1,850 lbs over your GVWR, a SRW 3500 of the same year has a combined GAWR at 700 lbs over its GVWR, and my 2500 has a combined GAWR that is 2,500 lbs over its GVWR.
Why does the 3500 SRW, which is well below the max 14k GVWR of it's class, only has 700 lbs separating its combined GAWR from it's GVWR, yet both our trucks, which are at the max GVWR of our classes, have over 1,800 lbs and 2,500 lbs separating our combined GAWR from our GVWR. Hmmm!?!
