naturist
May 06, 2014Nomad II
The two 20 amp 120 volt circuits cannot be combined. They will either give you 240 volts or short out and burn up the generator, depending on how you wired that.
A 4000 watt generator produces only 16-2/3 amps at 240 volts, which is why there is no 30 amp receptacle on it. The only way you can get a full 30 amps would be to spring for a 2:1, 240 volt to 120 volt step down transformer.
44,068 PostsLatest Activity: Jun 17, 2026
