mcsandman's avatar
mcsandman
Will this vehicle safely do the job?
Going to by a 2015 f150, which will weigh 5,000# and will tow in excess of 11,000#. I want to know, in ya'lls opinions, if that truck would do fine pulling a TT with these specs:
Dry Axle Weight (approx. Lbs.): 5375
Dry Hitch Weight (approx. Lbs.): 670
Net Carrying Capacity: 3955
Gross Dry Weight - Lbs.: 6045
Gross Vehicle Weight (GVWR) - Lbs.: 10000
Exterior Length (approx. w / hitch): 27'3"
  • bid_time wrote:
    You need an F-250 to pull a trailer that will likely weigh less then 8,000 lbs?
    I prefer a HD truck, but to each their own..
    Many many people are pulling very large trailers with 1/2 tons, too large IMHO but Ford, mainly, says they can do it.
    If all you are doing is pulling a trailer with an empty bed that's one thing, but if you take bikes, quad, a dog, or anything in the bed that has some weight to it you run out of capacity very quickly.
    Location has a lot to do with it as well. What many people do out Midwest or east I would never do in the PNW.
  • X2
    Your getting right up close to the limits and what about the stuff that goes into the truck. What is that going to do the GCVW to the truck.
  • Why limit yourself to a marginal vehicle for what your asking of it?
  • You need an F-250 to pull a trailer that will likely weigh less then 8,000 lbs?
  • After pulling for many years with an at capacity truck and now pullling with a truck that has way more capacity than I need, I would go for an F250.
  • Probably but you'll get better answers if you define the configuration of the truck, there are many configs.
