walker111's avatar
walker111
Winter tires on f350
Have a 2012 f350
Have always ran a dedicated winter tire on my f150's
Question? What ar some of you running for a winter tire?
Mine stock are Michelin LT275/65r 20
Did not like them in our cold Calgary last winter!
Thanks
  • I've run dedicated Bridgestone Blizzak W965's on my truck for the last 2 years in both the High Sierras and Rockies. Highly recommend them.
  • The M55 is not a dedicated winter tire that is why in my post i said year around and said i used the Dean wintercat with studs which is a winter tire.
  • What has worked for me .
    I have had more success by buying the cheapest load range E tire STUDDED that also has MORE SIPES from the factory .
    I replace the snow tires with a lot more tread left than my highway tires .
    The current set are cooper 265/75R16 load range E .
    I have tried many brands and have tried to use the softer P rated but in big sizes .
    I have tried the studded snow tires like BFG which have a bigger block design .
    I have run separate wheels and tires for winter use since 1977 .
    I have had a string of 3 /4 ton pickups that I purchased new every 5 years .
    Because i am replacing the snows when the tread gets down to 3 /32 to 5 /32 " i find i am just better off buying cheap but with a Load Range E rating and studding them.
    We live on a hill about 400 feet above downtown .
    It can be down to bare pavement in town but still we have 2 inches at home .
  • walker111 wrote:
    The toyos m55's are not a winter though? Are they?
    Nope. They can be studded,but aren't a winter tire.
  • 4x4ord's avatar
    4x4ord
    Explorer III
    I just ran my worn out Michelins last year but am considering the Nitto Crosstek HD as a year round tire:
    Crosstek HD
    The problem is I don't think they are available in Canada yet. I guess if you want to go the dedicated winter tire route you could buy some 18" rims and use the M55's.
  • For a dedicated winter tire i like the Dean Wintercat with studs. If not running a dedicated winter tire then M55 is hard to beat for a year around tire. I have M55's on both my trucks and had the Deans on my Dodge in the winter when i had it.
  • X 2 on the M55's best winter tire and long lasting. problem is can't em for 20" rims :(
  • If you don't break a lot trail, I like the BFG All Terrain. Great traction on ice and snow pack, although not great in deep snow, doesn't clean out well. I have Kelly TSR's on a 3500 DRW. Great tire in deep snow and good on ice and snow pack. Hankook ATMs good on ice and snow pack, never pushed deep snow with them.
