joe_julie81's avatar
joe_julie81
Winterization of hot water heater?
After draining all the water from the tc,including removing the plug from the hot water heater, what else? The anode attached to the plug is half eroded away, I guess it should be replaced? Should the plug be left out so the inside of the tank might dry out. Should I blast warm air in there to try and dry it out? I'm trying to prevent premature electrolysis from pitting the aluminum. Any thoughts?
