Alaskan_Fly_Guy's avatar
Sep 20, 2015
Winterized w/compressed air
I winterized my TT with compressed air through the city water inlet with my compressor set at 25 PSI. I went through and opened each valve one at a time for over an hour. I uncapped the low point drains and the hot water tank plug. Of course emptied the Black and Grey tanks and let drain for an hour or so too. My problem is that the tanks still read that there is some in them? I know they have lied to me before. Is there any way there could still be water in my fresh water tank after opening and purging EVERYTHING with air, uncoupling the pump and leaving all low point caps and plugs out?
Sorry for being so long winded. This is my first TT and winterizing.
  • You mention opening the low-point drains, but did you also open the fresh water drain valve to empty the tank? There should be one under the tank under the trailer. You'll probably have to get down and look under the fresh water tank.
  • First, unless you pumped air down the drain. You didn't purge the tanks.
    After draining the tanks. You don't have any thing in there. however. I would suggest closing the Black tank, put your chemicals in, and add 5 gallons to avoid the DRY tank smell. Also close the low point drains, and the grey tank, but you don't have to put any water in it.
    No 5 gal won't hurt the black tank. There will be plenty of room for the water to expand as it freezes.
