wfs989's avatar
wfs989
Winterizing Arctic Fox 990
I am having trouble winterizing my AF 990. We drove to Alaska in September and stayed at campgrounds the whole way so also used pressurized water and my fresh water tank was always empty. I am now trying to put the antifreeze into my water lines and the water pump will not draw the antifreeze out of the gallon container. I have checked all the faucets and they are all closed,as are the low point hot and cold water drains, and I am now wondering if I need to pout some water in the fresh water tank to prime the water pump. Just wondering if anyone else has had the same issue.
Coming back across the Yukon with the fall colors was absolutely spectacular.
Thanks for your help.
