#1nobby wrote:
Thank you all.
I'll use the outside shower hose. That'll work for both the tank rinser and the city water inlet.
Genius!
Just to be clear. This technique DOES NOT winterize the city water inlet. To winterize that you turn off all faucets and allow pump to build up pressure and shut off. Then press the check valve at the city water inlet to back flush the antifreeze. You may have to pry out a small screen to access the check valve. Also stand aside when you press the check valve because water/antifreeze will spray out under pressure.
