towpro
Nov 02, 2015Explorer
there is a little valve in that city water opening, that has a spring holding it closed, with an oring in there. If your system is under pressure and you stick your finger in the city water valve and open it, this oring will get knocked off center. some times you can get it back, some times you need to replace the whole valve :(
44,071 PostsLatest Activity: Aug 30, 2026
