wowens79
Nov 20, 2016Explorer III
Winterizing toilet??
When winterizing, do you leave the pink stuff in the toilet bowl?? I've read the seals need to stay wet, but will the pink stuff damage them? Will it stayin the toilet bowl punk?
MFL wrote:
If you use the cheap ethanol based anti-freeze, it may dry out seals, and will evaporate. It only takes a few gallons to winterize, so I don't mind paying 5 bucks a gal, for higher quality. It won't evaporate, won't stain, and is actually a good lubricant for seals.
Jerry
