When winterizing, do you leave the pink stuff in the toilet bowl?? I've read the seals need to stay wet, but will the pink stuff damage them? Will it stayin the toilet bowl punk?
Community Alumni
Not applicable
Nov 20, 2016
My experience is that the pink will displace the water. After pumping anti-freeze thru the lines, I open the low point drains again and the first to come out is usually some water. Same at the fresh water inlet, when I push in the relief valve button, I typically get some water first.
