sac89's avatar
sac89
Winterizing with Air this time
As the summer is winding down and students are going back to school in a few weeks, I am thinking about trying a new process for winterizing my trailer. I have been using the Antifreeze in the pipes technique the past several years, however, we get warm snaps in the fall after the camper is buckled up.
This year I would like to try blowing out the lines with compressed air, so I can pull the trailer out on the occasional warm weekend. I do not know how to do this, so any advice as far as what kind of air compressor and instructions would be great.
Thanks!
  • treyster wrote:
    I have a related question, newbie here. I'll be doing my first winterization next month. If my water tank is empty,is it okay to dump pink into the tank and run the pump or do I need to disconnect the pump and siphon directly from the pink jug?
    No need for antifreeze in the fresh water holding tank - just draw it directly from the jug(s).
    Never put anti freeze in your fresh water tank
  • I use the same method as everyone else here with the air. I do put a small amount of pink stuff in the toilet bowl to keep the seal from drying out when I put some in the drains.
  • downtheroad wrote:
    Anti-freeze in the traps....
    Air through the lines.
    That's the way we have since we came across the plains in a covered wagon.
    +1, and some pink sticky stuff against the dump valves. Oh and a bit in the toilet bowl to keep the seal wet.
