Tiger8r
Apr 23, 2016Explorer
If you want a 50 A service go to your main panel and find two slots next to each other. Put a double pole 50 A breaker in these slots. Run 3 #6 gauge wires and one #8. 6s are for two hot legs and the neutral and the #8 is for the ground. Install the proper 50A outlet at your trailer. You have full 50A serv. For the trailer. What I did was to put in a 30A plug at our house to keep the trailer plunged into to charge batteries and we would only use 1 Ac IF needed and lights when prepping for a trip. The 30A requires a single pole 30A breaker, # 10 wire, 1 hot, 1 ground , and 1 neutral, and the proper thirty amp outlet. The thirty amp is the way I would go.
PM me if you have any questions
44,068 PostsLatest Activity: Apr 17, 2021
