time2roll
Jul 20, 2020Nomad
theoldwizard1 wrote:I stand by my recommendation to make it right.time2roll wrote:
At this point I believe it is best to separate the grounds to an independent bus in the barn subpanel.
If the installation was to code before the code changed your fine AS IS !
If you do not have 4 wires (2 hots, neutral and ground) going to the barn, disconnecting that bond would be dangerous !
I would not have it wrong on my property.
Just because you are entitled to avoid the new safety rules does not make it a best practice.
JMHO
