KampfirekidExplorerJul 20, 2020Wiring A 30amp RV Outlet - Ground & NeutralI wired up a 30amp plug in my barn this weekend to power the travel trailer when it’s in the driveway. My barn is wired with a 100amp service breaker cabinet off the house main service, which was ins...Show More
time2rollNomadJul 20, 2020So 3 wire 240v split phase.... not 4 wire. Dang I would be hoping the conduit is large enough to pull a ground wire. Good luck.
Related ContentAdding power outlets in slide with no wiringNo power on outside GFCI outletElectrical outlet issuesIs 12V supply wire to USB outlets rated for 15A?Outlet problem
