JeremyV
Jun 26, 2016Explorer
Thanks so much for your quick replies. The bus appears to be two different pieces one for each breaker which is fed by it's own hot wire. Only the left currently has the 30 amp hot feed coming in. I'm not getting any power to the right side breaker yet. I have yet to test it, but the A/C is not turning on wired to the new 20 amp breaker on the rights side. If the right does not test to have any power, should I jumper the wire from the left bus screw to the right bus screw?
Thanks,
Jeremy
Thanks,
Jeremy
44,068 PostsLatest Activity: Jun 21, 2026
