tattoobob's avatar
tattoobob
Wiring Question? 2000 Lance 1010
I bought a 2000 Lance 1010 last Tuesday I'm very happy with the camper as it's in great condition
I'm having a problem with getting the campers running lights working, I bought the wiring harness from AdventureRV and it came Thursday afternoon so I had time to get the wiring done and the truck to the beach for Friday
I got the wires run to the Battery 8 Gauge and ran all the wires to the lights but no mater what I did the running lights on the camper would not work
Am I missing something that has to be done special to Lance? Nothing in the paper work the camper came with says anything
Maybe something needs to be added to the truck?
Thanks for the help, Bob
  • I grounded my Lance truck side plug to the truck frame which worked great. 2002 F250.
  • wnjj's avatar
    wnjj
    Explorer II
    The ground for the running and turn lights needs to come from the truck. The camper battery ground isn't relevant. Check the ground in the camper to truck harness. If you're talking about the truck battery negative, that should be good enough. Does a test light work in the truck plug?
  • Yes, a good wire directly to battery should be good, however the lights may have a separate ground connection.
    What kind of truck is the camper on?
    You could have blown the fuses under the hood depending on make. Some have the trailer connector fuses under the dash.
    Is this the wiring diagram you are going by? Make sure the black and white are not reversed.
    Wiring diagram
  • enblethen wrote:
    No lights as specified now, would suggest a no ground issue.
    Should the ground go to the frame of the truck??
    and I would think the 8 ga. wire going to the battery would be the ground??
  • The old camper (1986 12' Real-Lite) had a ground from the lights to the plug and a ground from the battery to the plug 2 separate grounds it seems lance only uses one ground from the battery
  • I forgot to add that there are no break or turn signals either, all wires were tied into the trucks wiring harness that goes to the trailer outlets, I tested all the camper circuits( breaks, right, left, turn signals, and running lights) with 12v from the camper and they all work
    2005 Ford F350 SRW
  • The clearance lights should be connected to the taillight circuit in the camper. Some rigs have fuses for different functions in the camper. Look around where the cable enters the rig. Could be in back of a cabinet near the floor.
    You are talking the lights around the top of the camper and across the back?
    If you are also talking taillights, check under the hood for separate fuses for trailer connector. Those circuits are also used for camper connections on some.
