jtdl wrote:
westend wrote:
At the stage you're at, it's probably a good idea to install a 12V distribution panel. The power for the fridge can be lead off that, as will lights, water pump, fans, water heater, and any other 12V devices you choose to use. With a distribution panel, the circuit from 12V battery power to the fridge will be fused and protected.
Will definitely look into this. Sounds like a great idea. Thank you.
You're welcome. A quality distro panel (Blue Sea is one brand) would probably be under $30 and will definitely ease any 12V branch wiring.
