So i'm having a moment here. I want to wire a relay to send power to the back of the truck can't the description is a bit vague. Relay No, i don't need that much capacity but i figure why not. ...
You should be switching the positive and not the negative. The negative can us the frame as the conductor. Are you wanting to switch power for battery charging?
