jayw900
Feb 08, 2016Explorer
Wiring relays
So i'm having a moment here. I want to wire a relay to send power to the back of the truck can't the description is a bit vague. Relay No, i don't need that much capacity but i figure why not. ...
wing_zealot wrote:rhagfo wrote:I get all that, but you don't need a relay to operate those lights, all you need is a large circuit with a switch of the proper size in it to operate the lights. Only difference being they don't come on automatically with the backup lights. They come on when you "need" them with a switch. To each his own I guess.wing_zealot wrote:
Why are you using a relay? Just put a switch in the line.
Well because you can only run so much on a circuit before you over load a switch.
Take my Backup lights.
I have halogen backup light on both my TV and 5er! If I tried to run all six of my backup off of the stock backup circuit for power I would be blowing fuses all the time. Instead both sets are on relays, and grab power for a large circuit.
