jayw900
Feb 08, 2016Explorer
Wiring relays
So i'm having a moment here. I want to wire a relay to send power to the back of the truck can't the description is a bit vague. Relay No, i don't need that much capacity but i figure why not. ...
Bedlam wrote:
.............Since you plan to to connect to your trailer batteries, use the same type of heavy circuit breaker from the positive camper battery to heavy gauge wire and second heavy gauge wire connected to the trailer frame for ground into the same type of Anderson connector at the trailer tongue.
