MitchF150
Mar 23, 2013Nomad
My guess is the battery is bad, even if only 2 years old or you have more draw than you think..
Check to make sure if your fridge has a switch that helps keep the moisture down that it's turned OFF. It runs on 12v and is not necessary, especially when running off only the battery.
Check that the tv antenna booster switch is OFF. This also draws 12v power. What is your other 12v electric uses? Lights, furnace blower, radio?
Good luck!
Mitch
Good luck!
Mitch
44,071 PostsLatest Activity: Aug 30, 2026
