Cabman_850's avatar
Cabman_850
Wolf Creek 850 Freshwater drain
Hello all. Found this site a couple months ago while looking for a new TC. We recently purchased a 2013 Wolf Creek 850 to replace our much loved Northstar TS100. Going to miss that camper. Anyway, we got the camper home and needed to winterize it, but the freshwater drain plug is not working. I was told it was the exterior valve on the back right of the camper. I opened it up and nothing. We ended up cycling the water out with the pump into the grey tank and draining it, but I need to get the fresh water drain working. Any ideas? Thanks in advance for the help.
  • That is strange that it's not working. I wonder if it is clogged. You also have a freshwater drain in the sewer dump valve compartment that is operated by using the Water pump. There's both a hot and cold drain valve. The one in the rear right is gravity fed you may want to remove the screws take off the valve and inspect the hose.
    Congrats on the purchase you got a great camper.
    Nolan
