anutami
Jan 01, 2015Explorer III
Damionsnwbrdr wrote:
I laughed when I saw your picture of using the heater duct into the basement cause that is what I have right now. I too have a Wolf Creek 850.
Although my problem is I'm not sure if my fresh tank outlet froze and broke or is just lose and leaking.
How would I go about checking the fresh water tank outlet underneath the tank?
You didn't say anything about the flip flop holding the step up :)
Welcome and hope you love your WC 850 as much as I do mine. Sorry about your water issue. Did you just purchase your camper?
It is a real pain to check the outlet under the tank and I hope that is not your issue. You can barely wedge your had underneath the tank and feel for water. I scuffed up my hand pretty good trying to feel around. If you are looking down on the tank it should be in the drivers side front corner. You first have to carefully secure and button up the rats nest of wires to access the bottom of the camper (get a bunch of zip ties) then remove the saturated insulation. If you have a leak there you will have to remove the bottom panel of the camper and should have a dealer do it.
Any other questions please let me know and post pictures if you can.
Nolan
44,071 PostsLatest Activity: Aug 23, 2026
