joeshmoe
Jan 12, 2015Explorer III
LoL...No. Haven't quite lost that lovin' feelin'. Not yet.
This is recent. Last month. It was tricky to figure out exactly where it was coming from because I couldn't see it to get to it. It wasn't outright dripping and only intermittent. Not every time I filled up, did it leak. Water would apparently stream down the hose to where it passed by the floor, then spread out from there.
The first time it flooded, I was clueless. Figured it was the sink drain because the slip joints were all but tight.
The second time, I traced it back, but couldn't see it. I was able to reach back and get a 1/4 turn on the hose clamp. Woo hoo!
That was it, I thought. Ran water through it. No leaks. Great. Or so I thought. This particular time was so bad, we had to postpone our trip til I got it completely dried out. It was a mess.
Third time was when I went to flush the tank. Thinking I fixed it by tightening the hose clamp previously, I just let the water run this time. After not even a couple minutes of flushing, there was a lake under the cabinet, AGAIN! Now I'm pi$$ed. I immediately yanked that fill box off.
The hose clamp wasn't even slid onto the hub and the hose was all bunched and pinched as you can see in the pic.
I have an idea to eliminate filling from the outside entirely by removing the existing hose from the tank and using an 1-1/4" rubber drain coupling and stubbing up a piece of PVC with a threaded cap to fill from inside the camper, under the step. That way, I can also pour in my 7 gal. reserve water jugs from inside as well. I don't know. Probably a dumb idea. But after three floods,
I hate that fill hose with a passion.
44,071 PostsLatest Activity: Aug 23, 2026
