MORSNOW
Sep 12, 2016Navigator III
johndeerefarmer wrote:Better to ask before you spend your hard earned money on something that may or may not work for you.
I am looking at a WC or maybe the lightest AF.
I have some general questions about them.
Can you make the WC's comfortable in temps as low as freezing and as high as mid 90's? [COLOR=]I can only comment on the cold temps. Yes, it is plenty warm with a good sized furnace for a small area. I have storm windows for winter use also, they were recommended from friends with Arctic Foxes with double pane windows that said they should have went with storm windows.
How big is the generator bay? Will two Honda 2000W's fit? or a Yamaha 2400W? Only one generator will fit sideways. I can store a stack of 2x6's for leveling my tires in front of it and still have room for the 120V/30A cable, Kryptonite lock cable, funnel, on the side.
Are any of you using the 2500W Onan? is it noisy? How long does propane last running it? Super noisy and burns through the propane, but convenient. Almost everyone recommended getting a portable gas unit.
Is the Coleman 9k unit large enough for 90-95 degree weather?
How hot does the bunk area above the cab get? Or is it ducted? There are no ducts in the cab-over area.
Where do you store fuel for the generator? I use the spare gas for the SxS ATV on my trailer. There is room for a small can next to a portable generator, but I prefer exterior storage. You can also store small cans in the front wheel wells which are accessible from inside the WC camper.
Where do you store your tools? In the truck, in the front wheel wells, in the generator compartment, under the dining seat, in the cab-over step. Lots of options.
Where do you store your lawn chairs, ice chests and other gear? My Strongback chairs fit under the dining table when traveling. I've also stored large reclining chairs on the cab-over bed. Everything else goes on my ATV trailer.
Sorry for all of the questions.
44,072 PostsLatest Activity: Aug 23, 2026
