I have the weboost amp, indoor antenna panel and outside I put up the trucker, non ground plane antenna. I installed the antenna on a painters pole and pushed it up 15 feet over the rig. Works very well except when windy as the antenna is moving. Nothing is perfect as there are so many variables. Trees in the way, hills as you cant get a signal through dirt. That said if there is path I stream netflix. I also just bought and am waiting for the directional antenna from Wilson. As I set up camp and dont move for a week. So aim it the best tower should increase my through put. I work while camping over the summer so being connected is very important. I use my iphone as a hotspot then connect to my laptop. I also hae a backup system. Hawkings smart repeater that can connect up to a wifi hotspot. Dual systems whatever works the best gets used.
As far as dollars? One job pays for it all, the rest are gravy. Happy trails
