The_Texan
Apr 04, 2013Explorer
TriumphGuy wrote:Very satisfied with the truck and its ability to tow the weight in the mountains of the west. Mileage is 18 highway empty, 15 in town and 11-12 towing, so again, satisfied with those numbers. We did get the optional 20" wheels and had the level/lift kit installed by the dealer. Our payload is just under 2K and towing capacity is 10.4K, more than ample for our 10K towing. I use Tow/Haul mode when towing and it stays in 5th most of the time with a normal RPM of 18-2400, at highway speed. During a normal(4%-5%) climb, it goes up to around 28-3000, and if the grade is steep(7%) around here, then it will climb to 3600 but still maintain speed. It has a built in engine brake in Tow/Haul mode and what ever speed you have set on the cruise is the speed maintained down the grades. They come with a factory installed brake controller and the ride is very nice. DJ, a member here, has seen it with 1500# setting in the bed and can vouch that the truck sets level with that weight. IMO, the GM 6.2L max tow is an awesome combination.
Tell me more ... does the tranny shift quite a bit through the hills when towing? What kind of speeds can you hold going up grades? I'm told the biggest thing to get used to is the revving engine, going up high to get into the power. And info about the GM 6.2L I'd like to hear too :)
44,071 PostsLatest Activity: Aug 16, 2026
