~DJ~ wrote:
Reddog1 wrote:
Because they are AGM, could you not mount them on end, side by side where the existing battery is? You could put the battery cable terminals toward the front of the TC, with a piece of Styrofoam between the battery and front wall, with the same strap concept you have to hold the batts against the wall.
Considering the work involved to install the two 6-volt batteries, what will you gain?
Wayne
My 31 Trojan has 130 amp hours. The 6 volts have 225 EACH!!!
When you wire 6v batteries in series you double your voltage, but it does nothing for the amp hours. You still only have 225 amp hours. It's still a big increase over the 130 amp hours provided by your Group 31 battery.
