805gregg wrote:
joerg68 wrote:
~DJ~ wrote:
My 31 Trojan has 130 amp hours. The 6 volts have 225 EACH!!!
But the 225 amp hours are at 6V, meaning you can draw 1 amp from the battery for 225 hours at 6V.
For 12V, both batteries combined have 225 Ah together. Still not bad.
You don't add the two 225 amps when used in series, you still only have 225. A solar panel would keep the one original battery charged and be a better and lighter investment
So, if I used two 12 volt at 130 each would I get 260? I have 100 watt solar but doesn't work so good in the timber!!
