~DJ~ wrote:
Holy Cow AnEv942!!!! That is very impressive!!!
I am definitely going to look into modding the cabinet.
I have another question. If two 6 volt batteries rated at 220 AH stay the same when doubled to 12 volt what happens when they are quadrupled?
Will 2 130 AH 12 volts double to 260? If so, it sounds like 2 12 volts would be better than 2 6 volts. :h
And as was brought up earlier, if 1 of the 6 volts fail I'm dead in the water but not so with twin 12 volts.
When you series batteries, you add the voltages but the AH rating stays the same. When you parallel batteries the voltage stays the same but you add AH ratings.
