lonegunman
Oct 13, 2015Explorer
2015 F-350 DRW has 14,000lb GVWR. With a CG of 58 inches this camper should sit a couple of inches behind the rear axle. If you got a box stock, no option gas engine single cab truck you would stay under the gross weight.
A diesel, DRW, super or crew cab and make it a Lariat or King Ranch and it will easily break 8,000lbs unloaded. Add this whopper of a camper, two people, a tank of fuel and some gear and you hit 15K no problem.
