420RVfun's avatar
420RVfun
Wow! I'm learning a lot.
So, I'm pretty much in over my head. But, I will continue. Way more water damage than I could have imagined. I'm replacing supports and have had to lift the rear end because it sagged due to the rotten wood. Lots of staples coming out, thinking of using metal tape on inside to help reinforce where they have been removed(aka-fallen out). Most of the floor is getting replaced. I'll try to get some pictures up.
I read about vapor barriers. Thinking I should do this, lots of little holes in the old floor membrane. Can I put plastic on the rubber floor membrane then add Floor joists and foam board insulation or should plastic go on top of floor joists? Does this make sense?
And another question? I believe that there is mold on some wood that is still strong. Do I just spray with bleach water and that will kill it, or should I do more extensive cleaning. I really want to keep some of these boards because a lot has come out already.
BTW, I am handy but not professional tradesman.
44,071 PostsLatest Activity: Sep 18, 2026
