Mike_Up
Apr 07, 2014Explorer
A pop up isn't like a travel trailer though, it's a tent on wheels with the cheapest lowest performing appliances, no insulation.
Walls are just 1" X 1" wood framing with luan backers and glued on aluminum siding. You could construct the walls for a very low cost.
The floor is particle board (structure wood) which would also be cheap.
An entire tent can be purchased at bear creek canvas or other places for $1000.
Furnace is a forced draft fan 16KBTU. No ducting or anything.
AC is a typical 13.5K AC but is not ducted as well and not thermostatically controlled.
No oven or microwave either.
No waste holding tanks.
No DSI water heater with AC heater, just pilot lit gas.
No properly vented drain system that's tied together.
No dual propane tanks or even an auto changeover regulator.
No TV, amplified antenna or cable hookup wiring either as travel trailers.
Fridge is either a small 1.9 CF model with no freezer or a 2.5 CF model with a freezer big enough for 1 hot dog package.
Bathroom could be an expense but not as much as a travel trailer bathroom with porcelain toilet, sink/vanity, and tub/shower with tub surround.
The 2 most expensive areas are the lift system and the roof. The roof on the Jay Flights is no less expensive offering trusses and ducting for the AC along with skylights.
Lift system is the only real expensive.
So if it were a smaller travel trailer the expense would not be a rip off, but next to a 'tent' trailer, yes.
When I bought my older 2008 Jay Flight 19BH (22.5'), it was only $1000 less than the 26BH, which I didn't have a capable enough truck to tow at the time. The only difference between the 2 was that the 26BH added a queen bedroom ahead of the sofa, everything else was EXACTLY the same. They probably sold more 26BHs so the cost difference was smaller.
Same thing today: 19RD MSRP = $19,650 (19RD replaced 19BH) ; 22FB MSRP = $20,021 ; 26BH MSRP = $20,721
